Mar 29, 2012 3:57 PM UTC
UNDO / REDO
anyone out there had the UNDO and REDO icons just suddenly go "greyed out"?
they were working a few days back andnow they don't work anymore.
even ->EDIT ->UNDO & ->REDO are greyed out
WF4 / M210
TIA
    Mar 29, 2012 4:11 PM UTC
    They do get disabled in certain circumstances, but they should come back
    as you work. Saving, activating the window and some other things will
    'reset' them so they won't work until new actions are taken. Then you
    should be able to undo back to the last reset.
    Doug Schaefer
    Mar 29, 2012 9:39 PM UTC
    Mark Steffke was correct. i had 2X protk.dat files and i edited the wrong one. i renamed to XXXX.dat.old and all is good.
    thanx Mark
    his reply:
    I seem to remember that if you have toolkit apps registered, it disables the undo/redo. Im about 80% sure on that. Makes sense because toolkit apps could do any number of things to parameters or geometry, triggered from events, and pro/e couldn't track that if they wanted to.
