May 18, 2016 2:17 PM UTC
units behind dimensions
I need to put unit behind dual dimensions.  I can manually put the "in" behind the top line but cannot put the "mm" behind the second line.  Any thoughts?
    18-Opal
    May 18, 2016 7:20 PM UTC
    Hi Michael,
    There is no direct option available by which units can be shown next to dual dimensions.
    I would suggest to add text next to the dimension and set the drawing option dual_digits_diff such that to have minimum number of decimal places to the secondary dimension. It will reduce the gap between dimension and text.
    Amit
    May 19, 2016 2:15 AM UTC
    ‌Is it a requirement? This situation is usually covered with a general note.
    May 19, 2016 11:53 AM UTC
    ‌they want it this way for the manuals
    May 19, 2016 12:56 PM UTC
    The best way is probably to pad the end of the dimension with spaces, either in the suffix or after @D in the dimension properties. Create a note with the units, use the grid properties to align the note with the dimension, and associate the note with the dimension so that if it moves the note moves with it.
    You can also use super-scripts and sub-scripts but the units get oriented on with the primary dimension so they appear shifted up.
