Aug 10, 2010 5:40 PM UTC
Units of Measure
I am extracting the mass properties using ProSolidMassPropertyGet. I
would also like to know the units of each item that is returned in the
ProMassProperty structure. I understand how to get the principal unit
system but that only identifies the base units (length, force, mass, time,
temperature) and not derived units. Does anyone know how to retrieve the
derived units?
The derived units can be seen by clicking Edit->Setup->Units and clicking
the Info button for one of the unit systems. How do I get these derived
units? Do I have to derive them myself?
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (business)
+1 520.545.6399 (fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
