Update: WF3 reorder
The tech support guy has filed a new SPR on this issue, hopefully to get
it fixed in WF3 instead of having to wait until WF4.
    An update on this old issue with corrupted footers in WF3 (a corrupted footer does not allow feature reordering).  The SPR has been approved and will be implemented in WF3 M100:
    You opened Call 5717812 with PTC Technical Support on 16-May-2007, with the following description:
    "Feature reordering in the model tree is unpredictable when the Model has a Footer in it."
    Under further investigation, I had opened the Software Performance Report (1370933) so that our Development team could investigate this issue further.  Our Development team has now resolved this issue, and resolution details can be seen at https://www.ptc.com/appserver/cs/view/spr.jsp?n=1370933.
    The issue has been resolved in Pro/ENGINEER Wildfire 3.0 M100.
    The expected release date for Pro/ENGINEER Wildfire 3.0 M100 as per the product calendar at: http://www.ptc.com/cs/product_calendar/PTC_Product_Calendar.htm is August 2007.
    You can request the latest datecode of our software containing the fix at:
    http://www.ptc.com/appserver/cs/software_update/swupdate.jsp
    Good for PTC, stepping up and moving a fix forward on this critical issue.
    Original PTC|User threads on the topic:
    WF3 reorder - http://portal.ptcuser.org/index.php?mo=fo&op=st&thread=4881
    Summary: WF3 reorder - http://portal.ptcuser.org/index.php?mo=fo&op=st&thread=4882
    Update: WF3 reorder - http://portal.ptcuser.org/index.php?mo=fo&op=st&thread=4889
    Doug Schaefer
