Updating to next datecode
Hi I am running WF3 M020. I downloaded M030. When I run it to upgrade, it tries to connect to a PTC server. It asks me for my proxy details (address and port)which are correct, but then it can't connect. It doesn't give me an option to enter in my password and username. Can anyone suggest what I am doing wrong, or if there is another way to do this? Thank you. Shaun
    I haven't tried it your way. If you downloaded the 3 discs, I would just move the previous version out of the way and install the new one into the old loadpoint location. Then, copy the loadpoint\bin folder from the old install into the new loadpoint and go from there. Regards
    I didn't download the 3 discs. I downloaded the upgrade file MED-60449-CD-350_M030_i486-nt-installer.exe from the website, just over 15 megs. Running this file, it wants to upgrade my current setup, but then gives the problem as listed below. Thanks, Shaun
    If I had to download the 3 discs, it would mean about 1.5 gig to download as opposed to 15 meg. Shaun
