Using the .psf file to copy configs down to users
Hello all,
Does anyone use the .psf file to launch Wildfire2? In 2001 we use the
ptc_startup.bat file to set some environment variable, copy configs,
remove and/or copy other files to the users workstation when they launch
ProE. Is this possible in the psf file? I also noticed that the psf
file is located in the bin directory. When you launch the ptcsetup.bat
file doesn't it over write the psf file? How can you keep the psf file
custom to what you want it to do and not create the possibility of over
writing the file when the user does a ptcsetup?
Thanks In Advanced!!
JHengel
