Value out of range..
When creating an extrusion and entering a thickness value in the placement/options/properties box of .05 the system tells me that "You have entered a value .05 that is out of range (.174 to 1000000) click ok to correct..." it will not let me create a extrusion using I put in a value higher than .174.
I can although create the extrusion with the default value (above .174) and change the dim to .05 and the extrusion will be created.
Is there a setting somewhere that contols this or is something not set-up correctly.
