18-Opal
Jul 21, 2014 2:26 PM UTC
Variable chamfer like a variable round?
Wildfire 5.0 / Creo Elements Pro 5.0
Is there any way to make a variable chamfer like a variable round? I poked around the chamfer command, looked at the help files, searched both the exploder, and the community and didn't really see anything...
-marc
    Jul 21, 2014 3:57 PM UTC
    Depending of your geometry, perhaps you could:
    - make a variable round.
    - make a sweep surface between the 2 generated curves by the round feature.
    - extend this surface if necessary on 4 boundaries.
    - make a cut with this surface.
    De : Marc DeBower [
