Variable patterning in Wildfire
    On the dashboard, left most window, change from Dimension to Table and you
    will be able to pick all the dimensions you would like to alter.
    Bill Kunz
    MCAD Specialist
    Alcon Laboratories, Inc.
    (949) 753-6709
    william.kunz@alconlabs.com
    Use the Ctrl key to select multiple dimensions in a single direction.
    Just like any other feature in Wildfire
    Thank You,
    Vaughn McDaniel III
    Mechanical Engineer
    JR Automation
    13365 Tyler
    Holland, MI 49424
    Ph 616.820.3330
    Fx 616.399.4443
