Vertical Mouse
Has anyone ever used the Evoluent Vertical mouse? If so, is it compatible with Pro-E WF 4? Does it really help ease wrist tensions? Any input would be helpful. Thanks! Chris
    I also want to get the Evoluent Vertical mouse, however any mouse will work with Pro-e, mine only concern is if it easy on the wrist. Maria
    CBenner1-VisitorAuthor
    Not true that any mouse will work. Some mice have serious driver issues when used with Pro-E and cause very interesting graphic problems. So far Kensington has worked the best for us here. Intellipoint was bad news.
    i have it and i love it. it all depends on the person i think. it works with wildfire 2 and wildfire 3, so i would think it would be fine. it basically mimics the way your arm rests when you are hold a beer bottle sitting on a table....
