Nov 11, 2010 6:00 AM UTC
Very slow rendering in case of Pro/E WF5
Hi all,
I am using Pro/E WF5 M050 for modelling. While modelling I am facing rendering problem.
Pro/E is taking too much time for rendering edges of the model/planes, which is hitting performace badly.
Can anybody help me in this? How I can improve my rendering?
Is there any way to improve performace of Pro/E?
I am using Windows 7 x64 with 4GB ram.
    7-Bedrock
    Nov 16, 2010 10:59 PM UTC
    Render size and antialiasing are going to be the basic settings that can affect the render speed most. I haven't used WF5 rendering but check the settings that involve antialiasing (edge smoothing) and reduce it. If you have the advanced rendering and are using HDRI/Global illumination these effects are very computationally intensive.
    Nov 17, 2010 1:12 PM UTC
    Thank you for the reply Jason.
    I checked that but still issue is there but slightly improved.
    With similar settings, I am getting good result on XP OS. Is this because of Win 7?
    7-Bedrock
    Nov 22, 2010 5:42 PM UTC
    Weird, I can't see how Win7 would slow it down. I think you need to file a tech issue with PTC and let them sort it out for you. There could be a config.pro option that may help.
    Dec 23, 2010 11:29 PM UTC
    I was experiencing the same problem as the one you just described when I was using a mobile intel intergrated video card. When I'm using a Radeon HD (my laptop can switch between two video cards), the problem disapears. What kind of video card are you using?
