DomenicLaritz
Jul 4, 2012 10:11 AM UTC
View field inspections with Manikin extension
Hello everybody,
does anyone of you create view field inspections by using the Manikin extension?
If so, could you share the instructions how to do this?
Best regards, Domenic
DomenicLaritz
Jul 24, 2012 5:53 AM UTC
I found an idea, how to perform view field inspections using the BMX extension (page 21): http://www.qucosa.de/fileadmin/data/qucosa/documents/5994/data/Behavioral_Modeling_BMX.pdf
Oct 19, 2012 4:37 PM UTC
Hi Domenic,
Yes, you can use User-Defined Analysis to make view obscuration. The following video illustrates how to do it
http://communities.ptc.com/docs/DOC-1388
Vincent
