2-Explorer
WF2 Licences
When I run PTCStatus to see what licences are available and in use on the
server, it reports a number of Flex_Eng packages and a number of Foundation
Advantage packages. In addition, there are some Mech_Foundation packages and
some Process_Modeler packages. Then there are some Advanced_Assembly sets
and some Advanced_Surface sets.
I am clear about the Foundation Advantage packages, and I think the Flex_Eng
packages are probably Flex Advantage packages. However, do you know what a
Mech_Foundation package and/or a Process_Modeler package might be?
I guess if I grab an Advanced_Assembly set and an Advanced_Surface set at
the time of starting a Foundation Advantage package, I effectively have
another Flex_Advantage package. What can I do to make the Mech_Foundation
and Process_Modeler packages into something useful?
This is Wildfire 2, so it is historic Pro/E - as close to collectible as
software gets...
