WF4 to WF2 conversion?
I there an easyway to take a WF4 file and convert it to a WF2 file?
Thanks Steve
    You can export the file and import it into WF2, but you will not be able to modify it. I believe PTC has a patch for WF2 that can open WF3 file with limited functionality, but I do not know about WF4.
    Peter Stockhausen
    Infotech Aerospace Services
    You will need to download and install the GCRI tool, it is a free download and will allow you to open WF4.0files with limited function in WF 2.0. (As well as WF 3.0)
    You can get more info and download the GCRI tool here: http://www.ptc.com/products/granite/gcri/index.htm
    Doug
