WF5 curves color
In older ProE versions, it was easy to change curves color.
With color panel, we could select curve by clicking them one by one or all curves in a retangular area.
Then we could assign color.
Now, we don't have curves in selection filter anymore.
So, how can we assign a color to a set of curves ?
GB
    Use the geometry filter for selecting and changing the curve colors
    Mark Peterson
    Sr Design Engineer
    Igloo Products Corp
    You can select them from the model tree, RMB, PROPERTIES, when the line style dialog box opens, set the color you want. If you have a fairly large model tree and manage layers so that all your curves are collected under one layer, you can selet them from there, but after making your selection, you will need to move your mouse back into the graphic window for the RMB to bring up the PROPERTIES option.
