What is the "designate" column for in the "Parameter" window?
What happens if designate is checked or unchecked?
I'm relatively new to Pro/E and this forum, but a long time CAD (CADDS 5, IDEAS, Mechanical Desktop, Solidworks) user. Thanks!
    Kevin,
    I can't speak for other Product Data Management (PDM) systems other than
    Pro/INTRALINK, but if the Pro/E Designate box is checked, then the
    parameter is passed to the corresponding (same name) Pro/I Attribute.
    It then can be used inside of Pro/I to be included in table display's,
    Sorting, searching (Locate in Pro/I), and so forth.
    --Jim Augeri
    MCAD Tool Support - Engineering Quality and Tools (EQT)
    Honeywell Aerospace
    9201 San Mateo Blvd. (MS B-3)
    Albuquerque, NM 87113
    Phone - 505.828.5808
    Fax - 505.828.5500
    james.a.augeri@honeywell.com
    This e-mail message and any attachments are for the use of the intended
    recipient(s) and may be controlled by U.S. export control laws. Any
    unauthorized review, use, disclosure or distribution of this
    communication in whole or in part without the express written consent of
    Honeywell, or the U.S. Government as required, is prohibited. If you are
    not the intended recipient(s), please contact the sender by reply e-mail
    and destroy the original message and any copies of the message as well
    as any attachment(s) to the original message.
