What's the best way to learn Pro Engineer?
So I'm a student, somewhat familiar with AutoCad, but I haven't used ProE at all. I have access to the program at my school. Most employers list ProE experience as a desired job skill. If you wanted to learn ProE, where would you start? The help file? An internet site? Just start playing with features? Amazon.com has a bunch of books on ProE, but they are pricey enough that I would rather not just select one at random. Are there books anyone would recommend? Thanks in advance, and if there is already a topic about this, a link to it would be much appreciated.
    Below is a pasting from another thread on reference books. This is my suggestion for learning Pro/e on your own. There were some other suggestions for reference material in this thread Steve Kowalski Joined: 05 Mar 2007 Posts: 55 Location: Westbury, NY Posted: Thu May 24, 2007 9:15 am Post subject: -------------------------------------------------------------------------------- Greg: I sympathize completely! My recommendation (for what it's worth) to learn Pro/E on little or no $. Would be: 1)Buy the student version. 2)Find out what references are available on ebay/amazon, etc. But one of those, maybe one of the Toogood workbooks also. 3) Familarize yourself with the basic commands, making simple parts, assemblies and drawings. Once you've done this, drop it like a 'hot-potato'. 4) Pick a real item to model and create assy's and dwg's. for example: Model your deck or your house, or the lawn mower. Do all the parts down the nails and screws,sheet-rock, etc. The point here is to do something real, don't waste anymore time with these book projects. From my experience, I find that I only really learn new software when I need to use it. At this point use the books only as a referance. I would't waste any time or $ (personal $) on these Pro/E courses, they're all very basic. If can model your own deck or house, you'll have surpassed the skill level you'll acheive from these courses. Once you have these items modeled and dwgs made you'll have somewhat of a portfolio to showcase your skills. From then on, I'd register with a freelance design website (www.cadground, etc)and try to get some freelance work that way. I think if you devoted yourself about 4hrs a day, for about 2months you could be a fairly proficient user. Anyway, just my opinions/suggestions. Best-of-luck! Steve
    Hi Joel, When looking for books, search for the author Roger Toogood. I have a handfull of his books and most are very good. I am also teaching myself pro-e. There are plenty of websites that are very good, I use the forums over at MCAD Central regularly and find the members very skilled and helpful. Wayne
    Thanks, I will check out the Toogood books and those forums.
