Sep 7, 2011 12:57 AM UTC
Wheel button is not exiting a command, help?
I downloaded the Creo Elements student edition. I was giving it a test run and when I go to sketch something, the wheel button doesn't exit the command. I am using Windows 7. Can anyone help me with this?
    Nov 4, 2011 8:15 PM UTC
    Probably you should change assignments of your mouse buttons in the system - the wheel button must be the middle button...
    Jun 23, 2014 3:57 PM UTC
    "change assignments of your mouse button"
    How do you do it?
