Jun 28, 2016 6:56 PM UTC
When you are assembling items in Creo?
Hello To All,
When you are assembling items in Creo, and you have to use angle offset. You have to use negative value, but as soon as you hit regenerate it jumps to the positive value. Is there a way to get it where it will stay the negative value?
Thanks Billy
    2-Explorer
    Jun 28, 2016 11:59 PM UTC
    Bane of my angular constraint existence. AFAIK Creo always normalizes the angle to 0<=x<360. I have no idea why. It really irritates not having negative angles; instead I often have to assemble so that variation avoids negative angles.
    Creo (up to 2.x) also doesn't have a control for the sense of the angle, so it's not like the positive direction can be flipped.
    Best compromise is to create a parameter for the angle and then set up so the sense of the angle has the nominal position at 180 degrees. Then a relation can be used: angle_dimension = 180 +(or -) angle_parameter. The "-" is handy when the sense of the constraint is wrong.
    Jun 29, 2016 12:58 PM UTC
    1.] you can set following config.pro option
    SHOW_DIM_SIGN  yes
    2.] you can add dollar sign to enable minus values in relations, for example
    $angle_dimension = -45
    MH
    bmclemore1-VisitorAuthor
    Dec 14, 2016 11:05 PM UTC
    Thank you, Martin. I will have to try that next time I have a model where I have to use angles to assembly something.
