Why can't I edit my posts in the "Pro/ENGINEER" fo
Has anyone an idea or could help me?
    only moderator or Administrator can edit the posted things. Infact if you need you can repost with the correct information in another...
    SylvainA.1-VisitorAuthor
    Normally I should be able to edit my own post (like in the other forums). http://www.ptc.com/forums/faq.php#15 Pro/E forum is the only one where I cannot edit my post... (regarding to the little messages in the bottom of each forum)
    "Pro/ENGINEER forum" wrote:
    You can post new topics in this forum You can reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You can download files in this forum
