Mar 30, 2012 7:16 PM UTC
Wildfire 2.0 & Windows 7
Has anyone been able to successfully run Wildfire 2.0 on Windows 7?
TIA,
Bruce
    Mar 30, 2012 7:30 PM UTC
    Hi Bruce
    I tried it several times on many computers (32 and 64bit).
    No, I can't run ProE Wildfire 2.0 at Windows 7 - it isn't supported by PTC - see here.
    Vladimir
    Mar 31, 2012 10:26 PM UTC
    Hi Bruce,
    I cant help you, I dont use it.
    old chris
    Apr 25, 2013 10:15 PM UTC
    If you have access to a successful WF2 installation (e.g. on a friend's/co-worker's Windows XP machine) you can just copy the loadpoint directory from the successful installation to your Windows 7 machine.
    The WF2 setup.exe program doesn't work because it checks for the OS and can't figure out Windows 7 (since WF2 was created before Windows was released).
    Note that this only works on 32-bit versions of Windows 7, I have never been able to get WF2 to work on a 64-bit version of Windows 7.
    Apr 26, 2013 6:19 AM UTC
    everyone can run WF2 on Windows 7 (32/64 bit) if he knows some tricks (as Kelly noted).
    Bruce, tell me exact combination of software and I'll let you know ...
    Martin Hanak
