wildfire 2 meets 3
How can I give data to my co-workers if I use Wildfire 3 and they use Wildfire 2? Thank you: I hope I don't have to repeat the whole work of the last 2 weeks in the Wildfire 2 version... Thanks and I wish you all a happy new year. Domenico Cacciatori
    Search the Knowledge Base for how to install the GCRI Granite Interoperability Kernel. Regards
    You could also save a copy of the file out as a Neutral file. This strips all features from the model tree, replacing them with a single Neutral feature so that you can't edit the model, but it may be sufficient for what you are looking for.
