Wildfire 4.0 - 64bit download
Hi Folks
I am getting a new computer with windows 7 (64bit).
I am trying to find the download to make wildfire 4.0 compatable with this OS. Can anyone point me in the right direction?
Fionn
    Fionn,
    The standard download for Windows will work with Windows 7. You only need to change advanced things if you are still working with Intralink 3.X. Please see http://communities.ptc.com/thread/33016 if you are using Intralink 3.x.
    DomenicLaritz
    But, if you run Pro/I 3.4 M070, it will run without changing advanced things!
    I can only vouch for M062 and there you need to run in compatibility mode and change fonts.
