Wildfire3 to wildfire 2
Hy, If I update form wildfire 2 to 3 then if I make some components in wildfire 3 can I save them in a format that can be opened and work on it in wildfire 2?
    Not really. You can save as a STEP (dumb solid) or other 3D format. There is a plug-in that uses the ATB to send files back and forth, but it is not a no-brainer to install. It allows 3.0 files to be opened in 2.0. You can't modify the model in 2.0, but you can add features that can be 'grafted' onto the model when re-opened in 3.0. Check TPI 132326 for details. Regards
    Ok thnakyou for answer !
    Can you explain me what is TPI 132326. thanks
