Windchill 9.0: check objects out from searchresults
If you do an Advanced Search or a Context Search you will be able to
multi-select and Check Out or Add to Workspace.
yes this should have gone in the Solutions list.
Steve D.
Quoting Chad Gentry <cgentry@sanyamerica.com>:
> I think I placed this in the wrong category, sorry.
    Also, I had the recommendation of using the search tab in the Pro_e interface. This gives thae desired ability of checking out the search results.This seemed to solve the issue. Thanks
