Windows overlapping in "Copy Geom."
I'm playing about working hard with WF3.0 doing some Published and Copy
Geom. The annoying thing is that when I bring in the data from the
copied file, its window appears in front of the window that I have all
the commands on and I have to keep resizing all my windows to finish the
action. Those of you that have been on WF3.0 must have experienced this
and I'm wondering if you could share any fix/workaround.
Richard A. Black
Lead Engineer
Eaton Corporation
16900 Aberdeen Road
Laurinburg, NC. 28353
Tel: 910-610-1788
Fax: 910-277-3700
    Richard,
    this happens when you have the copied file open in its own window before
    making the Copy Geom feature. If it is not displayed in any window before
    hand it will be retrieve in the nice little window that fits in front of
    your active model.
    Bjarne
    "richard black" <->
    08-07-2008 22:54
    Please respond to
    "richard black" <->
    To
    cc
    Subject
    [proecad] - Windows overlapping in "Copy Geom."
    I?m playing about working hard with WF3.0 doing some Published and Copy
    Geom. The annoying thing is that when I bring in the data from the copied
    file, its window appears in front of the window that I have all the
    and I?m wondering if you could share any fix/workaround.
    Richard A. Black
    Lead Engineer
    Eaton Corporation
    16900 Aberdeen Road
    Tel: 910-610-1788
    Fax: 910-277-3700
