Feb 18, 2011 6:41 PM UTC
XYZ data
What is the best way to create a pipe/tube from xyz data?
    Feb 28, 2011 6:46 PM UTC
    Steve,
    I use the offset coordinate sytem datum point tool to enter the xyz numbers.
    Start the tool select a coord sys point.
    Click in the lower box to make your points.
    Change the values.
    Then I go to insert / advanced / pipe and follow the prompts.
    Not sure if it is the best , but it works for me.
    Let me know if you need anything further.
    Later
    Brian
    Feb 28, 2011 2:34 PM UTC
    Hi Steve,
    are those xyz points the virtual corners (bends) or ragular points along the pipe?
    Constantin
    Mar 2, 2011 8:55 PM UTC
    They represent the intersection of two lines. I think there may be a better way to use XYZ data then INSERT, ADVANCE, PIPE. Possibly a family table. I don't have the piping extension.
    Thanks!
    Steve,
    Change the values.
    Later
    Brian
    Mar 2, 2011 9:16 PM UTC
    Brian,
    I tried it your way and it works great!
    Steve
