May 28, 2024 4:40 PM UTC
Creo 11 What's New
  • Apr 7, 2026 8:33 PM UTC
  • 2 replies
  • 13633 views
  • Translate All
Check out this video on Creo 11 from PTC Application Engineers. Presenters: , Lino Tozzi (Technical Specialist, Fellow) & Tom Quaglia (Creo Segment Sales).
May 30, 2024 5:26 PM UTC
WEBCAST Q&A
Question from Drew:  When an assembly is created using multi-body, and each of the bodies is checked into Windchill as separate parts, can other parts be imported into the multi-body assembly?  For example, importing a bolt and nut to the multibody sheetmetal part you were showing.
Answer:  Adding a bolt and nut would happen at the assembly level and not in a multi-body part.  We might need to know more about the use case.
May 30, 2024 5:34 PM UTC
WEBCAST Q&A
Question from Michael:  When you use multi-body, can you assign WTParts to the individual bodies, or just to the model?  From a BOM perspective, the example you were showing would be a structure with multiple parts - but how does that work with associations?
Answer:  The object get 1 WTParts by default.  Otherwise, you can designate a body so that when everything gets checked in, Windchill will recognize the multiple bodies without being multiple parts.
Question from Michael:   For the inseparable assembly, it makes sense to have the single WTPart and single CAD model.  But in the sheetmetal example, there is one CAD part model - or does it actually create a separate CAD part for each designated body?  In other words, if Body 2 has its own WTPart and you want to write an ECR to make a change, are you able to only change the CAD for Body 2 or do you end up changing the entire part with all the bodies?
Answer:  The sheetmetal part is made up of multiple bodies/  If you create an ECR on a single body, this is also impacting the overarching part, similar to changing a part in an assembly.
