Creo Advanced Assembly Tips & Techniques Session Recording (East Coast)
  • April 10, 2026 at 1:53 PM
  • 2 replies
  • 2752 views
  • Translate All
Check out this video on Creo Advanced Assembly from PTC Application Engineers!
Presenters:  Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
To dive deeper into the subject, check out PTC University.
Dayna_M14-AlexandriteAuthor
Webcast Q&A
Question from Anonymous:  Is skeleton model standard offer or special installation needed?
Answer:  No special installation needed but you do need the Advanced Assembly Extension (AAX) module.
Question from Anonymous:  From which Creo version onwards is skeleton available?
Answer:  Skeletons have been around since Pro/E 14 (back in the early 90s).
Question from Anonymous:  How does Windchill deal with skeletons?
Answer:  Windchill does not build a WTPart but it does know it is in the assembly.
Question from Anonymous:  Can you start with parts and build the skeleton later?  It is hard to understand what's happening with the skeleton when I don't see anything.
Answer:   Yes, but then you would use it for positioning mostly.
Webcast Q&A
Question from Walter:  How can you tell if a part was changed and no longer fits, or interferes?
Answer:  Windchill always marks models as modified that have been changed and interferences can always be seen with a Global Interference check.
