Jul 21, 2021 2:01 PM UTC
Creo Advanced Assembly Tips & Techniques Session Recording (West Coast)
  • Apr 10, 2026 6:33 PM UTC
  • 4 replies
  • 3025 views
  • Translate All
Check out this video on Creo Advanced Assembly from PTC Application Engineers
Presenters: Lino Tozzi(Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
To dive deeper into the subject, check out PTC University.
Jul 29, 2021 6:30 PM UTC
Webcast Q&A
Question from Carl:  Is a skeleton the same as a sketch?
Answer:  It is a specific sub-type of a part.  Once you create a skeleton part it can contain sketches, Datum features, surfaces, etc. to describe references, locations of the overall design.
Jul 29, 2021 6:33 PM UTC
Webcast Q&A
Question from J:  In top down design, should every subassembly have a skeleton model?  Or should you just pull all geometry from the TLA Skeleton?
Answer:  Hard to make a sweeping statement there, depends on complexity of the model.  Most designs would not require a skeleton in each subassembly, but if it makes sense, no reason not to where appropriate.
Jul 29, 2021 6:35 PM UTC
Webcast Q&A
Question from Saul:  If the skeleton is modified at some point process, do all related components update along with the skeleton?
Answer:  Yes, everything related to the skeleton is updated.
Jul 29, 2021 6:38 PM UTC
Webcast Q&A
Question from Mark:  What is the output file format of shrinkwrap?  Can I import it to other software packages?
Answer:  It is a .prt file.  By default it has an "_sw" appended to it's name.
