Creo "Advanced Modeling" Tips & Techniques Session Recording (West Coast)
Check out this video on Creo Advanced Modeling Techniques from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: February 8, 2022
Watch Guide
Overview
This 61-minute PTC Creo Tips and Techniques webcast, recorded on February 8, 2022, is a fast tour of core Creo Parametric advanced modeling techniques that experienced users often miss: smart selection, sketch relations, spinal and toroidal bends, trajpar and graph-driven sweeps, Flatten Quilt, and swept blends. Lino Tozzi (Technical Specialist, Fellow, PTC) presents the live demos and Ryan Butcher (Technical Specialist, Fellow, PTC) handles the Q&A. It is aimed at Creo users who already model daily and want robust ways to build geometry that is hard to create with standard features.
Chapters
This video has chapters, available from the player menu.
  • 0:00 to 2:39: Welcome and session overview
  • 2:39 to 5:04: Intent edges and robust selection
  • 5:04 to 8:38: Shift-key chains: tangent, surface and boundary loops
  • 8:38 to 14:42: Surface selection: seed and boundary, loops, Flexible Modeling
  • 14:42 to 18:10: Q&A: Ctrl vs Shift and negative volume in assemblies
  • 18:10 to 23:43: Living hinge and stent with spinal bend
  • 23:43 to 26:38: Tangent surface sweep with intersection references
  • 26:38 to 30:33: 3D coil with trajpar
  • 30:33 to 38:10: Cam slot with a graph feature and evalgraph
  • 38:10 to 40:46: Q&A: 3D splines and learning trajpar and evalgraph
  • 40:46 to 43:36: Helical grip: graph-driven cut vs Volume Helical Sweep
  • 43:36 to 48:28: Flatten Quilt and Flatten-Quilt Deformation
  • 48:28 to 53:17: Toroidal bend options
  • 53:17 to 59:00: Exhaust manifold: 3D curve, vertex round, swept blend
  • 59:00 to 1:01:00: Q&A: animating a spinal bend, and wrap-up
Key Takeaways
  • Right-clicking while hovering over an edge cycles to the intent edge of a feature, which selects every matching edge in one pick and keeps downstream features from failing when the edge count changes.
  • In Creo Parametric, Ctrl adds or removes single items and Shift builds chains and surface sets (tangent chains, surface loops, boundary loops, seed and boundary), the same logic as Ctrl and Shift in File Explorer.
  • A sketch perimeter dimension plus a sketch relation can force a closed profile to match an open length (153 in the demo), and a spinal bend then folds a living hinge in two features.
  • Trajpar runs from 0 to 1 along a sweep trajectory, so a relation such as angle = 360 times trajpar times 40 twists a section 40 times along any curve.
  • The relation evalgraph("graph_name", trajpar) drives a sweep dimension from a graph feature; the graph must have one Y value for every X value, and a graph drawn from 0 to 10 needs 10 times trajpar.
  • Volume Helical Sweep (the presenter recalls Creo 5 or 6; PTC article CS313656 says Creo Parametric 5.0) replaces a multi-feature graph-driven helical cut with one mathematically accurate cutter sweep.
  • Flatten Quilt plus Flatten-Quilt Deformation wraps text, bodies, or even a 2.5D lattice built on the flat quilt back onto a curved, multi-surface shape, with some unavoidable distortion.
How do I select all the edges of a feature in one pick in Creo Parametric?
Hover over one edge, right-click until the intent edge of the feature highlights, and click once to select every edge of that type. In the demo, one pick returns all four vertical edges of an extrude. Because the selection is defined by the feature rather than by individual edges, adding another edge to the feature later carries the round or other dependent feature along instead of failing it.
Watch: 2:39 to 5:04 (intent edge selection and a live edit that adds an edge without breaking the model)
How do I use the Shift key to select tangent chains and surface loops in Creo Parametric?
Select one edge, hold Shift, and hover: over an adjacent edge Creo Parametric offers a tangent chain, and over a surface it offers the surface loop around that surface, tangent or not. For quilts, the same Shift hover gives boundary loops. You can combine chains by holding Ctrl to pick another edge and Shift again to extend it.
  1. Pick the start edge: Click the first edge of the chain.
  2. Hold Shift and hover: Hover over an edge for a tangent chain or over a surface for a surface loop, then click to accept.
  3. Review the chain rules: After Ctrl+C and Ctrl+V, the Details button shows the chain type (tangent, partial loop, complete loop) and lets you adjust it after the fact.
Watch: 5:04 to 8:38 (tangent chain, surface loop, multi-chain and boundary loop selection)
What is seed and boundary surface selection in Creo Parametric?
Seed and boundary selection picks a seed surface and every surface out to a bounding surface you choose, including the seed. Select the seed, then hold Shift and select the boundary surface; releasing Shift briefly toggles the preview of the collected set. In the Details dialog you can choose whether the boundary surface itself is included.
Other surface tools shown include intent surfaces, solid surfaces (select all surfaces of a body, Creo 7 and above), and loop surfaces (Shift from a surface to its edge to collect every surface touching that loop), with Ctrl to deselect surfaces from the set. In Flexible Modeling, right-click offers shape selection (bosses, cuts, rounds) and tangent surfaces, and Geometry Search finds features such as all holes of a given radius so they can be edited together.
Watch: 8:38 to 14:42 (seed and boundary preview, loop surfaces, and Flexible Modeling selection)
Why is seed and boundary selection slow on large models in Creo Parametric?
Highlighting can slow down when a seed and boundary set contains thousands of surfaces, such as the interior of an engine block. Clear the preview option in the selection details and continue selecting without live highlighting.
Watch: 11:19 to 12:00 (preview toggle and the performance note)
How do I model a living hinge in both open and closed positions in Creo Parametric?
Model the hinge open, sketch the closed profile, make its length match the open length with a perimeter dimension and a sketch relation, and then fold it with a spinal bend. The result is two features, and a simplified representation that excludes the spinal bend gives you the open state as well.
  1. Capture the open length: Sketch a line between the hinge ends, convert it to a construction line, and add a reference dimension (153 in the demo).
  2. Sketch the closed profile: Draw the arc-shaped closed shape and add a perimeter dimension by selecting its entities and one variable dimension.
  3. Link the lengths: Add a sketch relation that sets the perimeter equal to the reference dimension.
  4. Fold the part: Use a spinal bend with the profile as the spine.
  5. Show both states in a drawing: Create a simplified rep that excludes the spinal bend, rename it Open, and place either rep in a drawing view.
The same spinal bend technique folds the flat surfaces of an expanding stent before merging, mirroring, patterning, and thickening them.
Watch: 18:10 to 23:43 (living hinge built in two features, stent example, and open and closed simplified reps)
How do I create a swept surface that stays tangent to two existing surfaces in Creo Parametric?
Create a variable section surface sweep and, in the section sketch, use Intersection references on the two existing surfaces, then make the sketched arc tangent to those intersection references. Tangency then propagates along the whole sweep in one feature. The demo uses Creo 8; the presenter notes the reference UI is a little different in Creo 7.
Watch: 23:43 to 26:38 (tangent surface sweep, including the fix when the arc is too large)
How do I make a sweep twist several times along its path in Creo Parametric?
Add a sketch relation that multiplies an angle dimension by 360 times trajpar times the number of turns. Trajpar is a sweep parameter that goes from 0 at the start of the trajectory to 1 at the end, whatever the trajectory length.
  1. Sweep a line section: Sweep a surface along any curve with a short line section (0.25 in the demo) and an angle dimension.
  2. Add the relation: In Tools, Relations inside the section sketch, set the angle to 360 times trajpar times 40 for 40 turns.
  3. Sweep along the new edge: Use the twisted surface's edge as the trajectory of a second sweep with a circular section to get a 3D coil.
The coil stays fully associative: editing the original curve updates the whole coil.
Watch: 26:38 to 30:33 (telephone-cord coil built in two features)
How do I use a graph feature and evalgraph to drive a sweep in Creo Parametric?
Create a graph feature that holds the unfolded profile you want, then drive a section dimension in a variable section sweep with the relation evalgraph("graph_name", trajpar). The demo cuts a cam slot whose height follows a graph named GG, built from two equal lines joined by a tangent spline over 1 inch with values of 0.5 and 0.2.
  1. Create the graph: Add a coordinate system, sketch the unfolded path from X = 0 to 1, and name the graph.
  2. Sweep the cut: Sweep a remove-material rectangle (0.25 in the demo) along the cam.
  3. Drive the dimension: In the section sketch, set the height dimension to evalgraph("gg", trajpar) and make the sweep a variable section.
Rules shown in the video: the graph must have exactly one Y value for every X value, a fully revolved version must end at the same value it starts, and a graph drawn from 0 to 10 needs 10 times trajpar. Sweeping a second surface with the same graph and intersecting the two gives the curve for a slot follower in a mechanism.
Watch: 30:33 to 38:10 (cam slot driven by a graph, and scaling the graph for a revolved cam)
When should I use a Volume Helical Sweep instead of a graph-driven cut in Creo Parametric?
Use a Volume Helical Sweep when a rotating cutter follows a helical path, such as a grip pattern or screw threads, because it produces the shape in one mathematically accurate feature. The older approach in the demo needs a trajpar-driven helical sweep, an intersect curve, and a graph controlling cut depth, and the presenter notes that geometry "isn't quite right". The cutter can also be tilted, for example 10 degrees around the Z-axis.
Watch: 40:46 to 43:36 (2001 grip model rebuilt with a Volume Helical Sweep)
How do I emboss text or a lattice onto a curved surface in Creo Parametric?
Flatten the curved quilt with Flatten Quilt, build the feature on the flat quilt, and wrap it back with Flatten-Quilt Deformation. The demo embosses a name across several surfaces of a bottle.
  1. Flatten the quilt: Select the surfaces, choose Flatten, and pick an origin point for the flat quilt.
  2. Build on the flat quilt: Sketch on the flat quilt (text in the demo) and extrude it as a body.
  3. Wrap it back: In Flatten-Quilt Deformation, select the flatten quilt feature and the body.
Anything built on the flat quilt can be wrapped, including a 2.5D hexagon lattice (0.25 by 0.25 cell in the demo). Expect some distortion: the wrapped result is not an exact copy.
Watch: 43:36 to 48:28 (embossed name on a bottle and a wrapped lattice)
What can a toroidal bend do in Creo Parametric besides tire treads?
A toroidal bend bends geometry in two directions, and besides the 360-degree bend used for tire treads it can bend around a radius or around an axis. Bending around an axis wraps a shape around another body like a spaghetti noodle around a cylinder, keeping the wrapped length equal to the original. If the wrapped curve is a fixed curved shape instead of a straight line, the result changes completely; the demo swaps the line for an arc with Replace in Sketcher.
Watch: 48:28 to 53:17 (tire tread 360-degree bend and wrapping a curve around a cylinder)
How do I control cross-sectional area along a swept blend in Creo Parametric?
Use the swept blend's blend control options: perimeter control varies the perimeter linearly, and cross-sectional area control lets you set the area at each section and at points you add along the trajectory. In the demo, adding a point and entering 1,000 constricts the area linearly to that value, which suits pumps and manifolds where flow must be smooth. The same exhaust manifold builds its 3D trajectory by intersecting two 2D curves projected in different directions, uses a fill section with a vertex round, and uses Behavioral Modeling optimization to hit target areas.
Watch: 53:17 to 59:00 (exhaust manifold with a 3D curve from two sketches and swept blend area control)
Frequently Asked Questions
Q: When should I use Ctrl and when should I use Shift to select in Creo Parametric?
A: Use Ctrl for individual picks, such as three separate edges, and to deselect items. Use Shift to select a range, such as everything from a first edge to a last edge, the same way Ctrl and Shift work in Microsoft Office and File Explorer. (answered at 14:42)
Q: Can I get the negative (internal) volume of an assembly in Creo?
A: Creo Simulation Live flow and Creo Flow Analysis can create internal and external volumes on a part. For an assembly they first merge the parts into one, similar to a solid shrinkwrap, and holes in the assembly need to be handled in that merge model. (answered at 16:45)
Q: How do I show a spinal-bend part both open and closed in a drawing?
A: Create a simplified representation that excludes the spinal bend. The master shows the bent state and the rep shows the unbent state, and you choose the rep when you place each drawing view. (answered at 22:54)
Q: How do I create a 3D spline in Creo Parametric?
A: Two methods are shown: use the edge of a trajpar-twisted sweep, or intersect two 2D curves sketched in different directions with Intersect. There is no dedicated curve-curve intersection command. (answered at 38:17 and 54:21)
Q: Can I animate a spinal bend opening and closing?
A: Not directly: the spinal bend angle cannot be used as a driver in a mechanism. Model the parts as an assembly and animate that, or record a mapkey that changes the bend in steps, take a screenshot at each step, and stitch the images together. (answered at 59:06)
Links & Resources
Webcast Q&A
Question from Anonymous:  How do you know to use these relations like evalgraph, trajpar, etc.
Answer:  Consider using these types of relations and features any time you need to vary dimensions along a sweep trajectory.  Google Trajpar for additional examples.
Webcast Q&A
Question from Mark:  Sometimes it's hard to remember the difference between ctrl and shift.  Is there an easy way to remember which key to use?  Is ctrl like "addition" and shift like "alternate"?
Answer:  Think of it like they are used in Microsoft Office.  If you want to select individual geometries, use the CTRL key.  If you want to select multiple geometries, use the Shift key.
Webcast Q&A
Question from Marvin:  How do you capture both open and closed conditions of a living hinge in a single drawing?
Answer:  Use a Simplified Rep for each state and reference each rep when placing the views in the drawing.
Webcast Q&A
Question from Michael:  How does one create a 3D spline?
Answer:  Intersect curves, Trajpar with sweep, curve through points, are all options for creating 3D splines.
Webcast Q&A
Question from Sharon:  Can you use this technique for assembly operation cutout to get negative volume in assembly mode?
Answer:  Yes, however, using Creo Flow Analysis is an easier method, or even using multi-body techniques.
Webcast Q&A
Question from Theophile:  Can you show again how to select the 4 edges of a square hole, please?
Answer:  Curser over the first edge, then right click to pre-highlight the intent edges, then left mouse click to select them.
