Creo and Augmented Reality Tips & Techniques Session Recording (West Coast)
  • July 19, 2021
  • 4 replies
  • 2626 views
Check out this video on Augmented Reality from PTC Application Engineers
Presenters:  Ryan Butcher (Technical Specialist  Fellow) and Lino Tozzi (Technical Specialist  Fellow)
Original Date Presented:  February 23, 2021
To dive deeper into the subject, check out PTC University.
Dayna_M14-AlexandriteAuthor
Webcast Q&A
Question from Scott:  Is there a way to publish these AR models in a remote environment?  Separate from PTC website or servers?
Answer:  The "Freemium version is only through the PTC Cloud.  There is a solution to bring it to internal to your environment through the full version of Vuforia Studio.
Question from Scott:  If an added distance is greater than the distance to Target Plane, can you make it float in free space?
Answer:  Yes, it will appear to float.  The target will snap to the floor or table you're setting it on.
Webcast Q&A
Question from Roman:  Do we really need Windchill or can we publish directly from Creo Parametric or Creo View?
Answer:  You don't need Windchill.  You can go directly to Parametric or View.
Webcast Q&A
Question from Bruce:  Can an AR publication be recorded and saved to be circulated and viewed later (i.e. manufacturing, training, service, engineering...processes/procedures)?
Answer:  Those solutions are with our extended suite of AR tools, Vuforia Studio, Expert Capture & Chalk.  https://www.ptc.com/en/products/vuforia
Question from Bruce:  Can multiple AR publications be viewed at once?
Answer:  One experience at a time.
Webcast Q&A
Question from Martinez:  Can the person viewing the model in AR access view states for the model like a section view or exploded view?
Answer:  Yes, that is available in Creo Parametric 7.0.3
