Jul 21, 2021 2:06 PM UTC
Creo Behavioral Modeling Tips & Techniques Session Recording (West Coast)
  • Apr 10, 2026 7:42 PM UTC
  • 3 replies
  • 1814 views
  • Translate All
Check out this video on Creo Behavioral Modeling from PTC Application Engineers
Presenters: Lino Tozzi(Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
To dive deeper into the subject, check out PTC University.
Jul 29, 2021 7:09 PM UTC
Webcast Q&A
Question from Jacob:  When showing a parameter in a note, I find that the model has to be regenerated twice before the note will update.  Is there a way to get the relations to regenerate before the note is regenerated?
Answer:  The regeneration process works in the following order:
  1. Calculation of initial relations
  2. Regeneration of features, which changes geometry
  3. Calculating of post regeneration relations.
To avoid having to regenerate twice:
  • Geometry and mass properties related parameters.
    • Calculate geometry related parameters in initial relations.
    • Calculate mass properties related parameters in Post Regeneration relations
  • Reorder the relations using the Sort relations functionality
Question from Jacob:  Can you use a user created relation parameter as a goal to minimize?
Answer:  Yes
Jul 29, 2021 7:15 PM UTC
Webcast Q&A
Question from John:  Can I get the values to show up in the history tree, so I don't have to click in to a given feature to check it?
Answer:  Yes, they can be displayed in a column of the Model Tree.
Question from John:  Can I change feature names on the fly in an analysis or do I have to go back to the feature to rename, then rerun the analysis?
Answer:  You can name it on the fly in the analysis.  Just need to press enter once you type in the new name in the analysis window.
May 4, 2025 1:51 PM UTC
Hi
Although the user interface is out of date, the capabilities are incredible.
I was surprised that a workaround was required to get a result in units of liters because Creo doesn't have a direct measurement of liters.
Thnaks,
