Creo Cabling/HMX Tips & Techniques Session Recording (East Coast)
Check out this video on Creo Cabling/HMX from PTC Application Engineers!
Presenters:  Adam Manfredonia (Presales Technical Specialist, Principal), Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
To dive deeper into the subject, check out PTC University.
Dayna_M14-AlexandriteAuthor
Webcast Q&A
Question from Claudiu:  Replacing a connector with a different one, it will be difficult to resolve failures of the cables and wires?
Answer:  The easiest approach is to change the schematic, change the assembly and re-import the XML file.
Webcast Q&A
Question from Jim:  Is there 3rd party tool for creating data tables?
Answer:  I don't believe there is.
Question from Jim:  Will Creo parametric allow you to add a REF_DES parameter to your 3D models so when you import Creo Schematics that multiple components with Auto-Match on REF_DES parameter?
Answer:  There is likely a way to do that but the REF_DES is assembly specific.  Instead of creating a million REF designations, it is probably easier to just create one component and then define the REF_DES in each assembly.
Webcast Q&A
Question from Michael:  Has the output schematic to cabling always been XML format?
Answer:  Yes, that is the format the Creo Cabling understands.
Webcast Q&A
Question from Tony:  Are there any improvements with flatten harnesses?  In the past, the extension tends to be very cumbersome to use.
Answer:  Yes, this will be shown later in the demo.  This area has the most improvement.
Question from Tony:  If schematics is not available for whatever reason, can we still generate .nwf files as a substitute for Creo Schematics for later versions of Creo?
Answer:  Yes, you can still use .nwf for cabling.  That is not going away.
Question from Tony:  What would be the recommended method of locating the cabling network?  I tend to use datum point to avoid assembly references.
Answer:  Skeletons and TDD techniques are your best friend here.  That way you can control the external references created.
