Thanks for sharing. I found a lot of interesting information here.
I have used CCX for several years, with multiple versions, Creo, 4, 8, and now 11. Since moving to Creo11, I have found this tool to be drastically slower than how it worked in Creo10. I have used the same laptop when running in both, used the same model, have since gotten a new laptop, and still what would take minutes in Creo 8 takes over 20 minutes in Creo11. I am wondering if others are seeing this same issue? I have reached out to PTC on this, sent them the exact files I have used, the CCX setup information, even my config files, but the response I got was that they only saw less than one minute difference with Creo 8 versus Creo11. We had a demo on AutoCrear, and had tested that with the same model in Creo11, and the results were drastically different. More in line with how CCX ran in Creo8. The output does not even compare, as it was 1000% better, and when you went to look at any violations, it actually took and made a breakout in the assembly to see much better what each one was. it even gave you a pdf report for each part and each violation within minutes.
