Creo "Creo Simulate Advanced" Tips & Techniques Session Recording (West Coast)
Check out this video on Creo Simulate Advanced Techniques from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: February 22, 2022
Creo Simulate Learning
Webcast Q&A
Question from Anonymous:  Can we do CFD analysis through Creo Simulation?
Answer:  CFD analysis can be done with Creo Flow Analysis or Creo Simulation Live (CSL).
Webcast Q&A
Question from David:  When using contact analysis, sometimes I want to select more than two corresponding surfaces for the contact interface (like a multi-surface ramp).  But I also don't want to select the entire part and increase processing time.  The tool doesn't let me select quilts.  Is there a best way to do this?
Answer:  Use split surfaces possibly, or auto detect.
Webcast Q&A
Question from Mark:  I have a question about where to see which T-license version I have.
Answer:  Choose File/Help/System Information to see what licenses and extensions you have.
