Aug 5, 2021 1:49 PM UTC
Creo Mechanism Dynamics Tips & Techniques Session Recording (West Coast)
  • Apr 10, 2026 7:44 PM UTC
  • 2 replies
  • 2272 views
  • Translate All
Check out this video on Creo Mechanism Dynamics from PTC Application Engineers
Presenters: Lino Tozzi(Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: August 3, 2021
To dive deeper into the subject, check out PTC University.
Aug 5, 2021 5:08 PM UTC
Webcast Q&A
Question from Brent:  If you were given an allowable envelope, can you then overlay your actual envelope on that to compare?
Answer:  Yes, definitely.  The motion envelope is a part that can be used to do a static interference or clearance analysis in the assembly.
Aug 5, 2021 5:34 PM UTC
Webcast Q&A
Question from Kevin:  Can we use CAS for FEA?
Answer:  You can manually transfer the loads into Creo Ansys Simulation.  Transferring them automatically is on the roadmap.
Question from Kevin:  Which version of Creo is this? 7?
Answer:  It is Creo 7.0.  These techniques can be done in any of the Creo Releases.
