Creo Multi-Body Design Tips & Techniques Session Recording (East Coast)
Check out this video on Multi-Body Design from PTC Application Engineers!
Presenters:  Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
To dive deeper into the subject, check out PTC University.
Dayna_M14-AlexandriteAuthor
Webcast Q&A
Question from Kyle:  Would multi-body save the same as an assembly in SAP?
Answer:  I believe it will appear as a part.
Webcast Q&A
Question from V:  Can you assign a material to a body?
Answer:  Yes, each body can have it's own material.
Question from V:  Can you also have the bodies populate a BOM on the field of the drawing
Answer:   Repeat Region support in Drawings for Multi-body parts
Listing body names, parameters, values, material
Auto exclusion of construction bodies
Display options for PTC_REPORTED_MATERIAL in repeat region
