Creo Parametric 9.0 Manikin
  • May 19, 2022
  • 993 views
Check out this video on Automating Creo Parametic from PTC Application Engineers
Presenters: Lee Goodwin (Solution Consulting, Principal) and Ryan Butcher (Solution Consulting, Fellow).
Creo Manikin Learning
Webcast Q&A
Question from Stephen:  How do you open the Manikin Extension?
Answer:  There is a tab in an assembly on top called Manikin.
