Creo Parametric 9.0 Manikin
Check out this video on Creo Parametric Manikin from PTC Application Engineers
Presenters: Lee Goodwin (Solution Consulting, Principal) and Lino Tozzi (Solution Consulting, Fellow).
Webcast Q&A
Question from Anonymous:  Does Creo Design Advanced come with the Human Factors Extension?
Answer:  Yes, it is available with all newer subscription licenses.
Webcast Q&A
Question from Christopher:  I loaded Manikin library into Windchill years ago and never updated it since.  You mentioned Creo 9 changes something.  What have we missed?
Answer:  It has been updated.  You would only us the Creo 9 library if you are using Creo 9.  If you are not, then use the existing one from Creo 1.
Webcast Q&A
Question from David:  Does the mass of the manikin alter the suspension geometry of the motorcycle (in this instance)?  Valuable to know for reaching the ground concerns.
Answer:  You would not use Manikin for a Mechanism like study.  However, you do have the Center of Gravity for the manikin and you can place the mass at the point.
