Webcast Q&A
Question from Adam:  Does Creo have a 3D sketching function like SolidWorks does?  That function in their "weldments" extension made it very fast to create a 3 Dimensional skeleton to make tube frame structure.
Answer:  Use curve through points, or curve from intersect.  Contact me for a demonstration, if you would like.  rbutcher@ptc.com.
Question from Adam:  Is there an auto-generated cutlist for drawings?
Answer:  Yes
Webcast Q&A
Question from Eric:  Is it possible to make a custom size beam?
Answer:  Yes.  This can be done by editing the files that present Profiles in the library.
6-Contributor
Graham Croxford
Mechanical Design Engineer
Fisher & Paykel Technologies
T +64 (9) 2730600 | M 0064210583639
Fisher & Paykel Appliances Ltd
78 Springs Road
Auckland 2013
New Zealand
LinkedIn
Webcast Q&A
Question from Paul:  Are these features available in Creo 7?
Answer:  Yes, this is available in all Creo releases.
