Creo Parametric Piping Tips and Techniques
Check out this video on Creo Piping from PTC Application Engineers
Presenters: Adam Manfredonia (Solution Consulting, Principal) and Ryan Butcher (Solution Consulting, Fellow).
Creo Piping Learning
WEBCAST Q&A
Question from Kyle:  Is there a way to incorporate pipeline supports into pipeline, or are they laid out in the parent assembly?
Answer:  You could put them in the subassembly and have them to route with.
WEBCAST Q&A
Question from Mark:  What's the solid pipe option?  Is it just a rod?
Answer:  You can create solid or hollow pipes with a rectangular or square shape.  This functionality allows the use of piping for square or rectangular tubing for furniture and HVAC ductwork.  You can also create a solid or hollow circular shape,
Question from Mark:  After I have the piping done in my model, is there a way to "run it" and find out how much pressure there is in each pipe?
Answer:  You can use Creo Simulate Live, or Creo Flow Analysis to calculate that.
WEBCAST Q&A
Question from Stan:  Will PTC continue to support old pipe tool (creation of pipe part utilizing points - independent of connector ports)?
Answer:  Yes, there is not plan to discontinue that feature in Creo.
