Creo Render Studio
  • March 30, 2022
  • 11 replies
  • 3234 views
Check out this video on Creo Render Studio from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Tom Quaglia (Creo Segment Sales).
Webcast Q&A
Question from AnonymousWhat format of Step file will carry these material color properties?
Answer:  All, but the color needs to be checked on export.  It is was not chosen on export, you can't have it on import.
Webcast Q&A
Question from IanI never seem to be able to save the scene.  How do you do that?
Answer:  Lino showed the option to "save scene with model" under the scene tab.
Webcast Q&A
Question from JuanHow can you apply multi-colors?
Answer:  You can apply a different color to each surface.
Webcast Q&A
Question from OscarI wonder if an imported (stp or iges) can be rendered easily.
Answer:  Yes, provided the surfaces import cleanly.
Question from Oscar:  Is KeyShot a separate engine/license?
Answer:  The module Creo Render Studio contains the KeyShot engine.
Webcast Q&A
Question from RajeshIs it possible to export file with render?  If so, please suggest a good format.
Answer:  Yes, you can the choice of JPG, TIF or PNG.
Webcast Q&A
Question from RobertWould showing water in the tank need to be another part in the model that is classified by itself?
Answer:  Likely, yes.
Webcast Q&A
Question from Robert SWhat material would you use for the best, reflective mirror-like surface?
Answer:  You can use any material, but choose chrome.
Webcast Q&A
Question from ThomasCan we import it directly to KeyShot?
Answer:  Export to the KeyShot command.
18-Opal
April 13, 2022
Thanks for the video post.  Can you please allow speed control and/or post to youtube?
If you right click on the video graphics area you can Show Full Controls to change the playback speed.
18-Opal
April 13, 2022
Beautiful! I didn't know you could do that and missed it when I RMB.  Thank you!
