Creo "Resolving Geometry Issues" Tips & Techniques Session Recording (West Coast)
Check out this video on Creo "Resolving Geometry Issues" from PTC Application Engineers
Presenters: Mark DeCraene (Solution Consultant) and Ryan Butcher (Solution Consultant, Fellow)
Original Date Presented: July 23, 2024
Jaime_Lee
Community Manager
Webcast Q + A:
Tom (t.meyers ) Is there a config to turn off auto zoom in trouble shooter?
Answer:  Yes, there is. In dialogue box, under the view command is turn off auto refit.
Jaime_Lee
Community Manager
Webcast Q + A:
Tom ( @t.meyers )    Not a question but an observation about geometry checks. We have found that exporting step files is really where this shows up.
Answer:  Yes, I just mentioned that. Geometry Issues can severely impact interoperability.
Jaime_Lee
Community Manager
Webcast Q +A:
 Earl @edaley  Does this same check occur with imported geometry?
Answer:  Yes it does. Whether the geometry is created in Creo or imported, the same geom checks can occur.
Jaime_Lee
Community Manager
Webcast Q+ A:
Tom (@t.meyers😞
Is buring the datum in the feature the next level for training? I always try to do that. Really cleans up the model.
Answer:  It does keep the model tidy. I think it is up to user preference
Jaime_Lee
Community Manager
Webcast Q + A:
balaji
Is model A & B both with no geometry checks?  While trying to add model B to A through merge/inheritence(add body external reference) option fails due to type of reference skeleton setup. But when both A & B saved as step file and on merging the step files to new model C it works and gives a solid model. how to address the reference skeleton issue to directly merge the working part model B to A.
Answer:  Usually this type of errors are based on models A&B being of different accuracy.  Usually this type of errors are based on models A&B being of different accuracy. We would need to see the models to determine that.
Jaime_Lee
Community Manager
Webcast Q +A:
(Anonymous)
If you make a new feature to replace round 9 with a completely new feature does the geom check still occur? I have found newer versions of Creo are less likely to create that self-intersecting check.
Answer:  New features can sometimes use new algorithms and not have bad geometry.
