Feb 2, 2022 6:25 PM UTC
Creo "Reverse Engineering" Tips & Techniques Session Recording
  • Apr 9, 2026 7:47 PM UTC
  • 7 replies
  • 3778 views
  • Translate All
Check out this video on Creo Reverse Engineering from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Tom Quaglia (Creo Segment Sales).
Original Date Presented: January 27, 2022
Feb 2, 2022 7:31 PM UTC
Webcast Q&A
Question from Anonymous:  Can you please show a geometric comparison between a scan and a theoretically perfect model?
Answer:  This is done with Pro/Verify which is now in the Computer Aided Verification module.  Click here for more info.
Feb 2, 2022 7:33 PM UTC
Webcast Q&A
Question from Chris:  Even though it's not a parametric model, can you dimension features in the drawing?
Answer:  Yes, by putting points on the surface.
Feb 2, 2022 7:48 PM UTC
Webcast Q&A
Question from Stacia:  Can this make a facet a solid model after filling the holes?
Answer:  You could 3D print and machine.  It is a heavyweight model if you intend on putting it in an assembly as just a faceted model.
Question from Stacia:  What if you wanted a solid model for analysis?
Answer:  The end result of this process is a closed surface volume that you can solidify.
Question from Stacia:  Today we do this process in Geomagic software.  I look forward to doing some testing on this!
Answer:  This is Geomagic but is embedded in Creo.  The advantage here is that you never leave the CAD environment.  You can mix together scanned features and parametric features.
7-Bedrock
Jun 30, 2026 1:17 PM UTC
what do you ment by Geomagic , you have integrated Geomagic  or its a development from creo
Feb 10, 2022 8:44 AM UTC
thank you for this presentation. very useful as an introductory session.
can you, please share the models used in the presentation ?
Many thanks,
Feb 10, 2022 10:58 AM UTC
Great demo!
Can you share the files of the examples shown in the demo?
Yosef
Feb 11, 2022 7:26 AM UTC
@Lino_Tozzi @Dayna_M
