Creo Schematics Tips and Techniques
Check out this video on Creo Schematics from PTC Application Engineers
Presenters: Adam Manfredonia (Solution Consulting, Principal) and Lino Tozzi (Solution Consulting, Fellow).
Webcast Q&A
Question from Dan:  Is Creo Schematics included with Creo Parametric in any of the new Creo Design packages or is it a separate product?
Answer:  Only the lite version is included.  It is a separate license to get the full version.
Question from Dan:  Do Creo Schematics objects work with Creo Cabling, for lack of a better description, to have a related schematic of the circuits within the cable routing objects?
Answer:  Yes, a schematic can be exported as an XML and read into Creo Cabling to Auto route and check connectivity.
