Creo "Sheetmetal Design" Tips & Techniques Session Recording (West Coast)
  • January 12, 2022
  • 6 replies
  • 2800 views
Check out this video on Creo Sheetmetal Design from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: January 11, 2022
To dive deeper into the subject, check out  Sheetmetal Design
Webcast Q&A
Question from Anonymous:  Do you guys have a YouTube channel?
Answer:  Here is the link to PTC's Creo YouTube channel:  https://www.youtube.com/channel/UCCVNmtLPvRt1CrLyfrI3IYQ
Question from Anonymous:  Is it a good practice to use flexible modeling?
Answer:  It is an excellent practice!
Webcast Q&A
Question from Frank:  Is there a corrugated option?
Answer:  Not a specific feature for this.  Could create User Defined feature and use that going forward to create this style of geometry.
Webcast Q&A
Question from Kevin:  Can you weld the sheetmetal edges/joins?
Answer:  Yes, using the weld feature.
Webcast Q&A
Question from Sharon:  On performance improvement, I thought I read in order to get the benefit, requires complete regeneration and save.  If this is true, what does full regeneration mean?
Answer:  Using "Tools"/Model Player you can reset the regeneration of the model to the beginning, and then regenerate from there.
Question from Sharon:  Sketched form - looking for a way to taper only selected wall of the form.
Answer:  Do a Quilt form and then manipulate the individual surface with Flexible Modeling.
Did the powerpoint that Lino was talking about ever get sent out?
@RyanL.Butcher @Dayna_M
