Creo Simulation Live Tips & Techniques Session Recording (East Coast)
  • April 10, 2026 at 3:29 PM
  • 7 replies
  • 3605 views
  • Translate All
Check out this video on Creo Simulation Live from PTC Application Engineers!
Presenters:  Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
To dive deeper into the subject, check out PTC University.
Dayna_M14-AlexandriteAuthor
Webcast Q&A
Question from Anonymous:  How do edit and show the results at the same time?
Answer:  The CSL requires a regeneration.  As fast as the model can be fully regenerated, the model will re-mesh and solve.
Question from Anonymous:  Have you modified the material properties after selecting STEEL for this model? (Asking from personal issues assigning material from Creo default options and incorrect densities and possibly other parameters)
Answer:  For Structural simulations, you need Young's Modulus and Poisson's Ratio.  Those are usually pretty good in the library.  Thermal characteristics are usually good too for Thermal Simulations.  They are also editable.
Webcast Q&A
Question from D:  How does it handle the interfaces between where two parts are coincident (example:  a screw)?  Does it just treat the two parts as one body?
Answer:  Creo Simulation Live considers mating components in assembly as bonded.  Material differences are respected, however, they are fused together as if they were one body.
Webcast Q&A
Question from Calvin:  Can this be used on the Sheetmetal model?
Answer:  Sure, sheetmetal now works well with the newer builds.  In Creo 4.0 M130, we use the new Ansys Discovery solver that works well on sheetmetal parts.  That was an earlier issue but not so much starting with M130.
Webcast Q&A
Question from G:  Can thermal analysis simulate the actual heatpipe as it shows in the example?
Answer:  With other tools (Creo Flow Analysis) we can model fluid flow showing conjugate heat transfer but not in CSL.
Webcast Q&A
Question from Luis:  Can I launch regular simulation with the settings in Live Simulation or do I have to re-do them?
Answer:  CSL loads and BC's along with Materials transfer directly to Creo Ansys Solutions.  Only materials transfer to Creo Simulate.
Webcast Q&A
Question from Sarang:  Can we see temperature on surface due to this flow?
Answer:  In this tool, you really aren't looking at the temperature of the model, you are looking at the temperature of the flow volume.  It is not as accurate as a true conjugate heat transfer like in our other tool, Creo Flow.
Webcast Q&A
Question from Hermes:  Can thermal analysis handle an assembly with different material properties?
Answer:  Yes, material properties of all parts are considered during simulations.
