Jul 21, 2021 2:27 PM UTC
Creo Surfacing Tips & Techniques Session Recording (West Coast)
  • Apr 10, 2026 7:43 PM UTC
  • 7 replies
  • 2999 views
  • Translate All
Check out this video on Creo Surfacing from PTC Application Engineers
Presenters: Mark Decraene (Technical Specialist, Principal) and Ryan Butcher (Technical Specialist, Fellow)
To dive deeper into the subject, check out PTC University.
Jul 23, 2021 3:52 PM UTC
Webcast Q&A
Question from Jorge:  How can I split a solid's surface using an imprinted curve?  Is it possible?
Answer:  You would always need to have a surface for that.  For example you would need to create 4 imprinted curves to create a surface.  With Creo 7, we have the Split Body Command.
Jul 23, 2021 3:56 PM UTC
Webcast Q&A
Question from Eric:  I've often wondered why I would use a spline over a well defined curve.  Do you have other applications that splines are preferred, similar to "cleaning up" surface breaks?
Answer:  It's all about surface quality.  With the Style feature we have direct editing of that spline to really create high order surfaces.
Jul 23, 2021 4:04 PM UTC
Webcast Q&A
Question from Kevin:  With Multi-bodies, can Windchill track each body as a separate part?
Answer:  Yes, with Windchill 12, separate bodies can be tracked.  This was demonstrated during our Multi-Body Session.
Jul 29, 2021 7:22 PM UTC
Webcast Q&A
Question from George:  Was "replace" command previously called "patch" command?
Answer:  It has always been replace.  Patch would often describe a different approach for creating a surface.
Jul 29, 2021 7:23 PM UTC
Webcast Q&A
Question from Geoff:  How is the plane determined for the visual mirror...?
Answer:  When selecting Visual Mirror it will prompt you for a Plane.
Jul 29, 2021 7:26 PM UTC
Webcast Q&A
Question from Jordan:  For parameter functions such as "trapjar", is there a short list directory that lists these and their uses?
Answer:  Some examples are in the Help.  I can't paste a link here but just do a search on trapjar.
Jul 29, 2021 7:31 PM UTC
Webcast Q&A
Question from Raghu:  Is it possible to create a separate drawing print for each body (within the same part)?
Answer:  Yes, this is possible.
Question from Raghu:  So, with multi-body approach, Creo does not have so much of an issue with disjointed pieces of geometry>  Hope it does not get confused with mass properties. 😉
Answer:  You can have an unlimited amount of Bodies and each body can have its own Material and mass properties.  These are not confused.
