Nov 1, 2021 5:54 PM UTC
Creo Unite/Import Data Doctor Tips & Techniques Session Recording (West Coast)
Check out this video on Creo Unite/Import Data Doctor from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: October 26, 2021
To dive deeper into the subject, check out PTC University.
(Pop-out video for best experience and full screen option)
Nov 3, 2021 8:16 PM UTC
Webcast Q&A
Question from Brad:  I use IceM Surf 2020.  It is a .icem file format.  Is this available?
Answer:  Yes, it is on the file open list as *.icm.
Nov 3, 2021 8:17 PM UTC
Webcast Q&A
Question from Dennis:  Can you open VISI native files?
Answer:  Not natively.  You would need to use STEP.
Nov 3, 2021 8:24 PM UTC
Webcast Q&A
Question from Kevin:  Is there a config setting that will copy geometry when external references are created?
Answer:  Not an option to automatically copy geometry any time an external reference is made.  However, using an advanced assembly technique you can accomplish this.  Here is a link to the Advanced Assembly T&T session for your reference.  https://community.ptc.com/t5/Creo-Parametric-Tips/Creo-Advanced-Assembly-Tips-amp-Techniques-Session-Recording/m-p/739495#M670
Question from Kevin:  Are there any cases to use ATB going forward?
Answer:  No, Unite should be used in all cases.
Nov 3, 2021 8:30 PM UTC
Webcast Q&A
Question from Mark:  Can Creo be used to edit automotive class A surfaces?  Or is surfacing software like Alias serve a different market segment?
Answer:  Yes, it is best to create the natively in a single tool (Creo Parametric/ISDX).  It is difficult to import class A surfaces and get good quality.
Nov 3, 2021 8:33 PM UTC
Webcast Q&A
Question from Raghu:  Is all the functionality shown today included in all licenses of Creo, including the most basic one?
Answer:  Yes, with SolidWorks and CATIA for United collaboration.  Importing any native file format is also in all current packages.  Import Data Doctor is in every license we sell currently.
Mar 3, 2023 7:31 PM UTC
I wanted to watch the Import Data Doctor video today and there is audio only.
Jul 21, 2026 9:28 AM UTC
hello ptc community team
can your share the same step/iges model file for import cad data, doctor's practice
#chandan@ptecad.com
